dang007's avatar
dang007
Netgear genie installer does not run on Mac OS X Sierra even when using Control key and "Open"
Tried to install Netgear genie.  With OS X Sierra you have to hold control key and use "Open" from menu, as noted in a prior discussion thread.  However, doing this does not cause the installer to run on my Mac.  Suggestions?
  • Hi Dexter,
    I deleted the copy of the installer from my desktop, downloaded it again.  This time it worked using the "Ctrl, Open" sequence and installed genie with no problems.
    Thanks for following up,
    Dan.
