chaitu
Apr 04, 2017Follower
NETGEAR Genie is not connecting to router
When i was trying to connect netgear genie to the netgear router its displaying the error " login failed.the router response timed out " i am unable to connect to the parental controls and the bypas...
jerbla
Apr 11, 2017Apprentice
V 2.4.22
ElaineM
Apr 12, 2017NETGEAR Employee Retired
jerbla What's the model number of your router?
Latest Genie version is 2.4.38.
Are you using wired or wireless connection in accessing the admin page?
Will you be able to access it if you open your browser and type www.routerlogin.net?
- jerblaApr 13, 2017Apprentice
running the most recent version available of the Genie availble according to the Genie update?
Tried access through the routerlogin and the download does not work for mac, it does not go past veriffying stage.
wired access
Thanks
