chaitu
Apr 05, 2017Follower
NETGEAR Genie is not connecting to router
When i was trying to connect netgear genie to the netgear router its displaying the error " login failed.the router response timed out " i am unable to connect to the parental controls and the bypas...
jerbla
Apr 13, 2017Apprentice
running the most recent version available of the Genie availble according to the Genie update?
Tried access through the routerlogin and the download does not work for mac, it does not go past veriffying stage.
wired access
Thanks
jerbla
it also only offers 2.4.22 for mac, as in the option I am running?
- ToanApr 14, 2017Aspirant
I'm using the latest version of Netgear Genie (v2.4.38) connecting to my NightHawk R8000 router and have the same problem.
The older Genie version works fine on my Mac, PC, and iOS device but now all three are not operational after the upgrade.
Clicking on Parental Control box in the center also gives me the "You don't appear to be connected to the Internet" error even though I'm typing this message on the same machine.
- jerblaApr 14, 2017Apprentice
Nighthawk X6
- jerblaApr 17, 2017Apprentice
Hi Elaine any feedback?
Thanks
- DexterJBApr 18, 2017NETGEAR Moderator
Hi all,
Please try resetting the router back to factory defaults.
Dexter
Community Team
