chaitu
Apr 05, 2017Follower
NETGEAR Genie is not connecting to router
When i was trying to connect netgear genie to the netgear router its displaying the error " login failed.the router response timed out " i am unable to connect to the parental controls and the bypas...
jerbla
Apr 13, 2017Apprentice
it also only offers 2.4.22 for mac, as in the option I am running?
- ToanApr 14, 2017Aspirant
I'm using the latest version of Netgear Genie (v2.4.38) connecting to my NightHawk R8000 router and have the same problem.
The older Genie version works fine on my Mac, PC, and iOS device but now all three are not operational after the upgrade.
Clicking on Parental Control box in the center also gives me the "You don't appear to be connected to the Internet" error even though I'm typing this message on the same machine.
- jerblaApr 14, 2017Apprentice
Nighthawk X6
- jerblaApr 17, 2017Apprentice
Hi Elaine any feedback?
Thanks
- DexterJBApr 18, 2017NETGEAR Moderator
Hi all,
Please try resetting the router back to factory defaults.
Dexter
Community Team
- jerblaApr 20, 2017Apprentice
this will involve setting up all my zones etc again I assume? Not an ideal solution and having resterted a number of times, this would seem a standard reply leaving me to reset all after. Any other thoughts perhaps before I send a day re setting after a restore?
