chaitu
Apr 04, 2017Follower
NETGEAR Genie is not connecting to router
When i was trying to connect netgear genie to the netgear router its displaying the error " login failed.the router response timed out " i am unable to connect to the parental controls and the bypas...
jerbla
Apr 17, 2017Apprentice
Hi Elaine any feedback?
Thanks
DexterJB
Apr 18, 2017NETGEAR Moderator
Hi all,
Please try resetting the router back to factory defaults.
Dexter
Community Team
- jerblaApr 20, 2017Apprentice
this will involve setting up all my zones etc again I assume? Not an ideal solution and having resterted a number of times, this would seem a standard reply leaving me to reset all after. Any other thoughts perhaps before I send a day re setting after a restore?
- jerblaApr 21, 2017Apprentice
does not answer why the server does not connect?
Reset is a simple avenue with complex re working? any other spultions please?
