dottieworf's avatar
dottieworf
Follower
May 02, 2016
Netgear Genie Login, Change Password
Have not been able to find an option in Netgear Genie to change the Router Login password from the default, password, to a password of my choice.  Is there a way to do this?
    It's all in the manual -  Page 122.
    • nwulff's avatar
      nwulff
      "How to change the admin password" is found in the User Manual for your router.  The page number will vary depending on your model. Determine your model number (usually on the device bottom) and look "User Manual" up at www.routerlogin.net.
  • "How to change the admin password" is found in the User Manual for your router.  The page number will vary depending on your model. Determine your model number (usually on the device bottom) and look "User Manual" up at www.routerlogin.net.
