Meo034
Sep 23, 2015Aspirant
Netgear Genie login username
Hi I recently purchased a Netgear Nighthack R7000 wireless modem and all seems to be working well except the Genie app on my IPad or IPhone. I changed the admin password from the default "passwor...
Mfcloer
Oct 07, 2015Aspirant
I found that the latest upgrade requires a minimum 8 characters. I went into router web and reset password to the 8 character minimum and now all back to normal.
- jahSJOct 21, 2015Aspirant
So there is a minimum password length required on the router in order to use the Genie ipad app? I thought my issue might be something like that as the login link was greyed out. Will that be changed to support whatever password the router supports? Thanks, Jeff
