GoldBeachBiker
Apr 25, 2017Aspirant
Netgear Genie message: has stopped working on windows 7
Anyone run into a message from Windows that Genie has stoppd working and check online for solutions: Details ... Problem signature: Problem Event Name: APPCRASH Application Name: NETGEARGen...
DexterJB
May 04, 2017NETGEAR Moderator
Hi GoldBeachBiker,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
GoldBeachBiker
May 05, 2017Aspirant
The router is excellent! I am quite satisfied with it. The Genie is a hopelessly ineffective and poorly constructed piece of software. Nothing but problems with it. I would encourage you to visit the reams of comments on various threads (including this one) showing displeasure with it. Netgear can do better. Your IT people can do better, one would think.
- WolfenRJun 14, 2017Aspirant
Hi and hope someone can help.
As with loads of others I'm getting the message 'Netgear Genie has stopped working'.
I have:
Win 7 64Bit (Desktop)
Router firmware V1.0.1.40
Kaspersky Internet Security (Genie stops whether or not KIS is running or protection paused)
Netgear Genie has been on my PC for several years, mostly working fine but only recently has stopped working as soon as I launch it.
I have uninstalled and re-installed Genie several times and the Genie software is the latest that is available from Netgear.
Any clues?
My thanks
- DexterJBJun 23, 2017NETGEAR Moderator
Hi all,
This may be an incompatibility issue with some updates with the operating system and the Genie program since engineering focus has shifted to the mobile apps (Android and iOS). We recommend using the mobile apps instead for the moment.
Dexter
Community Team
