raydeo
Jan 08, 2017Aspirant
Netgear Genie MS Visual C++ Runtime Error
Now that all is up and running from a less than perfect installation on Thew Nighthawk X6 R7900, I do have a question about an issue that keeps recurring. If I leave the PC for a while, I get the fol...
ElaineM
Jan 11, 2017NETGEAR Employee Retired
Welcome to the community, raydeo
This is the first time I have heard of this error.
What's the Genie version installed on your computer? Also what's the OS of your PC?
Have you tried uninstalling and reinstalling the Genie?
raydeo
Jan 12, 2017Aspirant
Hi Elaine, Network Genie is V2.4.36 running on a Dell PC with Windows 10 Pro V1607. No I haven't tried uninstalling and reinstalling and will give it a try.
This error comes up after Network Genie has been minimized and has been running for a while.
Thanks
Bruce
- ElaineMJan 12, 2017NETGEAR Employee Retired
Thanks! Feel free to give us an update as soon as you have reinstalled it.
- DarkOneXJan 12, 2017Aspirant
I have this same issue, just got my Netgear Nighthawk R7000 yesterday and set it up last night and installed the Genie software on my Windows 10 laptop and the software runs for maybe 20 min or so then crashes with the same runtime error.
- raydeoJan 13, 2017Aspirant
No change after uninstall and reinstall. For instance, I started Network Genie first thing this morning and now four hours later have the runtime message with the app cancelled. Malwarebytes did a scheduled scan earlier so not sure if these two programs conflicted.
- DexterJBJan 15, 2017NETGEAR Moderator
Please try installing the previous version of the NETGEAR Genie program linked below and check if the issue persists.
http://files.netgear-support.com/go/?a=d&i=g1l5p0fEvd
Dexter
Community Team
