susanmott
Dec 09, 2015Follower
netgear genie not compatible with windows 10?
HI, i see many discussions here about the problems with Netgear Genie app and windows 10. I have a newly purchased Netgear R6220. I installed the Genie app onto my windows 8 laptop, and it was work...
Retired_Member
Dec 09, 2015Look at the range rating on yours then check out r7000 range rating. If range is a problem you should consider a different router. Try installing genie using administrator, I installed genie last week on a Win 10 PRo 64 and it worked fine.
