susanmott
Dec 09, 2015Follower
netgear genie not compatible with windows 10?
HI, i see many discussions here about the problems with Netgear Genie app and windows 10. I have a newly purchased Netgear R6220. I installed the Genie app onto my windows 8 laptop, and it was work...
davedc78
Dec 09, 2015Initiate
My r7000 is working fine as a router in my fairly small one-bedroom apt, but maybe that is not surprising. However, I also cannot get the current version of Genie to run on a new Windows 10 machine. The older version, which I finally found a workable link to by scouring the forums, displays in a TINY window, almost unreadable. I would say the font is no bigger than 2 pt, maybe 3. Why write an app to behave this way? And nope, not changing my screen resolution, which already is at 175%, just so I can see Genie. So there are two Genie fixes needed. Get it to run reliably on WIndows 10, and do something to make sure it stays readable as people upgrade to higher and higher screen resolutions.
Tnx.
Retired_Member
Dec 09, 2015strange mine installed and worked fine, to be clear your win 10 was not an upgrade rather a full install
- DeeDeeLFeb 16, 2016Aspirant
I have a new laptop 64 bit windows 10. Cannot get Netgear Genie to run. I cannot connect my netgear R6400 wifi to connect to my laptop. I was told at BestBuy that the r6400 was compatible to Win 10 but it is not listed on the box. Do I return it?
- PaulieeFeb 16, 2016Tutor
Don't. Just delete Netgear from your contacts. They have refused to fix this long known problem. I have as of yet never received a fix for this.
- DexterJBFeb 16, 2016NETGEAR Moderator
Hi @DeeDeeL,
You should be able to install the R6400 without the NETGEAR Genie program and get it working. Have you gone through the installation procedure? If not, you may refer to the links below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/22697
http://kb.netgear.com/app/answers/detail/a_id/22717
If you are encountering an error when using the NETGEAR Genie program, you may refer to the following steps as a temporary work around.
1. Install the latest version of NETGEAR Genie. You may use the download link below.
http://netgear.com/home/discover/apps/genie.aspx
2. Once you have successfully installed the program, navigate to C:\Program Files (x86)\NETGEAR Genie\bin
3. Delete the drivers folder.
4. Download the drivers for the previous version of NETGEAR Genie using the download link below.
https://drive.google.com/file/d/0Bz-pjmQaYmk6Z0xTX3d3SVFLZ0k/view?usp=sharing
5. Unzip the file to your preferred location (Desktop would be easy to locate). It will contain the drivers folder.
6. Copy the drivers folder that you have just unzipped and navigate back to C:\Program Files (x86)\NETGEAR Genie\bin
7. Paste the drivers folder.
8. Relaunch the NETGEAR Genie programRegards,
Dexter
Community Team
- kalonaMar 19, 2016Initiate
Mine is a brand new Windows 10 computer and genie does not work at all
- PaulieeMar 19, 2016Tutor
And again, hoiw long before they fix this...it's been several months now...do your job IT Netgear Genie techs. !
- michaelkenwardMar 20, 2016Guru - Experienced User
Indeed, months since it came up, but more like weeks since Netgear reported that it knew what was going wrong. The delay may hint at the complexity of the problem.
It can't help that the bug does not hit everyone. I have just installed the latest version of the standalone Genie (2.4.18.0) on a brand new 64-bit PC and it works just fine.
