susanmott
Dec 09, 2015Follower
netgear genie not compatible with windows 10?
HI, i see many discussions here about the problems with Netgear Genie app and windows 10. I have a newly purchased Netgear R6220. I installed the Genie app onto my windows 8 laptop, and it was work...
michaelkenward
Dec 10, 2015Guru - Experienced User
susanmott wrote:HI, i see many discussions here about the problems with Netgear Genie app and windows 10.
Only because people turn up with problems. The many many people who, like me, don't have problems with Windows 10 and Genie see no reason to boast about it.
Version 2.4.20 works fine here in Windows 10.
- GeoFrancisDec 19, 2015Aspirant
Could you please tell me where you found 2.4.20 to download ? Thanks.
- michaelkenwardDec 19, 2015Guru - Experienced User
You could start here:
genie Landing Page | Apps | Discover | Home | NETGEAR
It should deliver the latest version.
Also the downloads pages for your hardware.
- originalhankDec 22, 2015Initiate
brand new ASUS laptop came with WIN10. Netgear Genie starts loading. then a NETGEAR Genie dialouge box pops up.
"NETGEAR Genie has stopped working"
"A problem caused the programto stopworking correctly. Windows will close the program and notify you if a solution is available."
Close Program action box
send fix info
