susanmott
Dec 09, 2015Follower
netgear genie not compatible with windows 10?
HI, i see many discussions here about the problems with Netgear Genie app and windows 10. I have a newly purchased Netgear R6220. I installed the Genie app onto my windows 8 laptop, and it was work...
michaelkenward
Dec 10, 2015Guru - Experienced User
susanmott wrote:HI, i see many discussions here about the problems with Netgear Genie app and windows 10.
Only because people turn up with problems. The many many people who, like me, don't have problems with Windows 10 and Genie see no reason to boast about it.
Version 2.4.20 works fine here in Windows 10.
GeoFrancis
Dec 19, 2015Aspirant
Could you please tell me where you found 2.4.20 to download ? Thanks.
- michaelkenwardDec 19, 2015Guru - Experienced User
You could start here:
genie Landing Page | Apps | Discover | Home | NETGEAR
It should deliver the latest version.
Also the downloads pages for your hardware.
- originalhankDec 22, 2015Initiate
brand new ASUS laptop came with WIN10. Netgear Genie starts loading. then a NETGEAR Genie dialouge box pops up.
"NETGEAR Genie has stopped working"
"A problem caused the programto stopworking correctly. Windows will close the program and notify you if a solution is available."
Close Program action box
send fix info
- michaelkenwardDec 22, 2015Guru - Experienced User
Welcome aboard.
originalhank wrote:send fix info
For that to happen you may have to talk to Netgear directly. This is essentially use to user. You'll have to watch this place for any suggestions for fixes.
I assume you have read all the messages before the one you tagged on to.
Before anyone can help, they may need to know a bit more. Which version of Netgear Genie are you running?
Are you actually running the standalone Genie? (Netgear also tags its web interface with the Genie label, just to confuse us all.)
The more you can say about your setup the better. We don't even know what hardware you have and what you are trying to do.
- marksitDec 25, 2015Aspirant
Latest version of genie. win 10 build 10586.36, netgear d6200.
will not load, "Netgear Genie has stopped working"
have run in admin mode
have run in compatability mode from xp up.......
windows troubleshooter identifies netgear genie as "incompatible program"
android app works fine, works fine also on my macbook pro running osx 10.11.2 (el capitan)
suggestions and ideas most welcome.
- NesimovicDec 25, 2015Aspirant
i'm having sam problem as you are. installed it yesterday works fine on iOS but not on win10 surface pro 3...
