susanmott
Dec 09, 2015Follower
netgear genie not compatible with windows 10?
HI, i see many discussions here about the problems with Netgear Genie app and windows 10. I have a newly purchased Netgear R6220. I installed the Genie app onto my windows 8 laptop, and it was work...
Nesimovic
Dec 26, 2015Aspirant
i'm having sam problem as you are. installed it yesterday works fine on iOS but not on win10 surface pro 3...
Gerry_SA
Dec 26, 2015Tutor
Hi,
I have Genie 2.4.20 working fine with Win10 on my Surface Pro 3, although I originally had the "stopped working" problem.
I have posted the "solution" that worked for me here.
The Win10Pcap file can be downloaded here.
I hope it may help.:smileyhappy:
Gerry
- nickva0517Jan 02, 2016Tutor
"Your app isn't compatible with Windows Insider Preview
If you try to use this app with Windows Insider Preview , it might not work correctly or might not work at all.
Go to the support website for the app developer, and check if a new or updated app is available for Windows Insider Preview ."
This is the message I received when I booted my HP TouchSmart m6 Sleekbook following my upgrade to Windows 10 a couple of days ago. I had a similar/same notice yesterday and came back to Netgear forum to find answers on my own. I found a number of problems, tried a few solutions mentioned, and finally reinstalled Genie. That "worked" for the balance of the day. But, when reboot came this morning, the above message was the result.
So, it would seem that maybe the "smart people" at Microsoft and Netgear, that get paid to help users not have problems, should get together and make the problem go away.
thanks,
nick
- DexterJBJan 02, 2016NETGEAR Moderator
Hi nickva0517,
We sincerely apologize for the inconvenience this has caused you. We are currently investigating this issue and working on a fix. Have you tried installing the previous version of the NETGEAR Genie program? If not, you may use the download link below.
https://drive.google.com/file/d/0Bz-pjmQaYmk6Vk92eE81a20xRjg/view?usp=sharing
Dexter
Community Team
- Kurt1121Jan 07, 2016Aspirant
Do you know if they are also working on a fix to the resolution issue (tiny fonts, small window)?
