susanmott
Dec 09, 2015Follower
netgear genie not compatible with windows 10?
HI, i see many discussions here about the problems with Netgear Genie app and windows 10. I have a newly purchased Netgear R6220. I installed the Genie app onto my windows 8 laptop, and it was work...
DcSpirou
Feb 06, 2016Aspirant
I forgot to tell you that I have R7000 and that with Windows 8.1 it worked very well, but since I installed Windows 10 there partition and formating my SSD, Netgear Genie launches well but does not launch automatically in the restart or by putting out(switching off) the PC and relighting him(it) later or later.
ERICTOTE
Look back to about mid January 2016 where I had similar problems and was advised by Dexter and another Contributor, which after some thought was the solution to my problems. Took a bit of time and patience but got there in the end, Good Luck
