susanmott
Dec 09, 2015Follower
netgear genie not compatible with windows 10?
HI, i see many discussions here about the problems with Netgear Genie app and windows 10. I have a newly purchased Netgear R6220. I installed the Genie app onto my windows 8 laptop, and it was work...
Retired_Member
Dec 15, 2015
Skiv wrote:Isn't it Netgear's responsibility to make sure that Netgear Genie is compatible with Windows 10 and not the other way round, and when does it propose doing something about it?
Works fine on my Win 10 pro 64 I formatted drive and performed a NEW install of OS.
Tested on r8000,R7000 & R6300v2
So tell us about your install
ec1955
Mar 06, 2016Aspirant
I had Genie on my laptop which had Win 7 - I upgraded to Win 10 now I cannot reinstall Genie because I get a message that tells me that Genie is not supported on Win 10 - This is NETGEARS problem as to informing users about such issues and hopefully giving us a fix.
When I treid to give Netgear my requested serial # it said it wasn't valid!!!!
They can't even get that right!!!!!!!!!!!!!
