susanmott
Dec 09, 2015Follower
netgear genie not compatible with windows 10?
HI, i see many discussions here about the problems with Netgear Genie app and windows 10. I have a newly purchased Netgear R6220. I installed the Genie app onto my windows 8 laptop, and it was work...
J245
Jun 06, 2016Aspirant
I don't see how a different browser will address the issue. It's a Genie app that is not showing the network map. When I log into the router directly using Firefox, I can see the attached devices.
michaelkenward
Jun 06, 2016Guru - Experienced User
Yes. I was confusing my genies. Netgear likes to confuse us all by using the same name for different "apps".
- J245Dec 02, 2016Aspirant
Thanks for your help initiating a ticket request with Netgear. I do appreciate your time and effort and the Netgear team. After months of discusion, attempts at different fixes, remote access, etc. the final resolution just came out:
I am answering on behalf of my colleague. Our higher level of support would like to convey to you that WNR2000v5 is not on the list of officially supported devices for Netgear Desktop Genie. Furthermore, NETGEAR has decided to focus more on the mobile apps rather then the Desktop genie, so we will not be adding support for WNR2000v5 on the Netgear desktop genie.
Thank you for choosing NETGEAR.
