eddyystop
Jun 19, 2014Aspirant
netgear genie not displaying
I have a D-Link DIR 655 router and the EX6200 is 5 feet away. My laptop connects to the ex6200. The device-to-extender, 2.4ghz and 5ghz lights illuminate. I fire up Firefox, the 2.4ghz and 5ghz light...
Retired_Member
Jun 19, 2014Not sure placing the extender 5 feet away is helping, doesn't the install instructions give you some guidelines for placement and state what the status leds should look like?
Make sure you are using a security level which is compatible with the extender
