Davidmeronuck
Oct 14, 2016Aspirant
Netgear Genie not working correctly with iOS 10 or Mac Sierra
Netgear Genie App doesnt recognize my R7000 is on the network once I updated to iOS 10. Also on Mac updated to Sierra, the Netgear Genie app crashes. In both cases, I have deleted and reinstalled to...
- Oct 26, 2016Thanks everyone. The updated app took care of the problem for me. Hopefully for all.
Ronhauck
Oct 24, 2016Star
Reset modem back to factory default. Restored both iPhone and iPad. I can only login and see map but cannot open to control anything. iOS 9worked good. Do you have app updated
DexterJB
Oct 25, 2016NETGEAR Moderator
Hi Ronhauck,
1. Which settings are you looking to change through the Genie app?
2. What version of the app do you have installed?
Dexter
Community Team
- RonhauckOct 25, 2016Star
I login I go to upper left box that says wireless I hit that on I get a thing that says netgear router not found or supported make sure not in guest setting an ivp6 not enabled. I have no problem if I use my browser. App is iOS 10
Can you email me I will show you screen shots
