Davidmeronuck
Oct 14, 2016Aspirant
Netgear Genie not working correctly with iOS 10 or Mac Sierra
Netgear Genie App doesnt recognize my R7000 is on the network once I updated to iOS 10. Also on Mac updated to Sierra, the Netgear Genie app crashes. In both cases, I have deleted and reinstalled to...
- Oct 26, 2016Thanks everyone. The updated app took care of the problem for me. Hopefully for all.
DexterJB
Oct 25, 2016NETGEAR Moderator
Hi Ronhauck,
1. Which settings are you looking to change through the Genie app?
2. What version of the app do you have installed?
Dexter
Community Team
Ronhauck
Oct 25, 2016Star
I login I go to upper left box that says wireless I hit that on I get a thing that says netgear router not found or supported make sure not in guest setting an ivp6 not enabled. I have no problem if I use my browser. App is iOS 10
- RonhauckOct 25, 2016Star
Can you email me I will show you screen shots
- DexterJBOct 26, 2016NETGEAR Moderator
Hi Ronhauck,
1. You can post your screenshots here.
2. You can try uninstalling the app and then reinstall the latest version since some have already reported that it has already fixed this issue.
Dexter
Community Team
- RonhauckOct 26, 2016Star
Did u get screen shots I uploaded
