Lovewifi
Oct 03, 2016Aspirant
Netgear genie not working due to IPv6 being enabled
I use netgear genie to block my kids from the wifi after hours. I was able to use it last night and this morning and now I'm not able to use it this evening, the message says my router is not supporte...
- Apr 06, 2017
Hi mrichie and chellelee8,
Please try using another device (Android, iOS, another computer) that is connected to the network.
Dexter
Community Team
Blastfurnace
Oct 08, 2016Initiate
Same problem. Worked for months now all the sudden the app stopped working and says check for IPv6 connection.
Extremely frustrating.
DexterJB
Oct 10, 2016NETGEAR Moderator
Hi Lovewifi and Blastfurnace,
1. What is the model number and firmware version of the router?
2. What version of NETGEAR Genie do you have installed?
3. Have you tried using another device (smartphone, tablet, PC)?
4. Please try uninstalling and re-installing the program/app.
Dexter
Community Team
