jarrodj609
Dec 26, 2015Aspirant
Netgear Genie not working
I see there was a topic that seemed to mirror my issue but it did not seem to be solved. I have a 6200v2 router. When I try to use the Netgear Genie I get the following:
DexterJB
Dec 26, 2015NETGEAR Moderator
Hi jarrodj609,
1. What is the version of the NETGEAR Genie program?
2. What is the firmware version of the router?
3. Is this computer wired to the router?
Dexter
Community Team
- jarrodj609Dec 26, 2015Aspirant
Hi Dexter JB,
NETGEAR Genie version 2.4.20
NETGEAR Router Firmware Version V1.0.1.20_1.0.18
Computer is wired to the router.Thanks for the quick reply.
Jarrod
- DexterJBDec 27, 2015NETGEAR Moderator
Hi jarrodj609,
I suggest updating the router's firmware to the latest version (1.0.3.10) then reset and reconfigure the router. You may refer to the links below for the steps.
Regards,DexterCommunity Team- jarrodj609Dec 28, 2015Aspirant
Hi Dexter JB,
Thanks for the prompt replies.
I manually updated to the latest version (1.0.3.10).
I uninstalled then reinstalled NETGEAR Genie.
When I try to access parental controls or router settings through NETGEAR Genie it still is not working. My parental controls are "stuck" on a filtering level that effectively blocks adult sites but I cannot adjust the filtering level if necessary and I cannot set-up time restrictions.
