wgblondel
May 20, 2016Aspirant
Netgear Genie NSIS Error
Hi. I try to install Netgear Genie on a Windows 10 64bit machine but the installer won't run. I downloaded it multiple times from Netgear's website on multiple computer but I have the same error...
jpoinpoin
May 27, 2016Aspirant
Bonjour,
I have the same problem, when the solution?
- DexterJBMay 29, 2016NETGEAR Moderator
Hi jpoinpoin,
Have you tried downloading the installer using another device/computer?
Dexter
Community Team
- jpoinpoinMay 30, 2016Aspirant
Bonjour Dexter,
Yes I have tried downloading the installer using another computer and it works.:manvery-happy:
But this does not resolve the problem I get on my usual PC (same level of Windows 10 64bits).:manfrustrated:
Jacques
