jjdonahue
Oct 21, 2015Aspirant
NETGEAR Genie Parental Control by Device has no effect
In NETGEAR Genie Network Map I see all the attached devices I rightclick my son's and daughter's devices - set Parental Contols Filtering to HIGH However i see no effect. Obvious adult sites are n...
DexterJB
Oct 22, 2015NETGEAR Moderator
Hi jjdonahue,
1. Are the sites still coming through?
2. Make sure that the DNS settings of the router are set to the OpenDNS. If not, you can have it manually set to 208.67.222.222 and 208.67.220.220 respectively.
Dexter
Community Team
jjdonahue
Oct 22, 2015Aspirant
Thank for the reply
Yes - still no filtering is apparent on any of 5 devices I'm testing (iPhone 4 and HP Windows 10 laptop added to my test list)
Because its all devices on my network, Im convinced its a central set-up issue
On my router - the primary DNS and Secondary DNS are the IP addresses you list above
- DexterJBOct 23, 2015NETGEAR Moderator
Hi jjdonahue,
1. What is the model number of the NETGEAR device?
2. What is the firmware version?
3. Have you tried resetting the device?
Dexter
Community Team
- jjdonahueOct 23, 2015Aspirant
Nighthawk R7000
V1.0.4.30_1.1.67
yes - I did a full restart by unplugging the router and counting to 10
Thank you for your assistance - it irks me that I can't figure this out
- DexterJBOct 26, 2015NETGEAR Moderator
Hi jjdonahue,
I suggest performing a firmware re-flash then reset and reconfigure the router. You may refer to the links below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665Regards,
Dexter
Community Team
