Jejskj
Jul 17, 2017Tutor
Netgear genie pause internet not working
Just installed NGenie app today on ios10.3. Unable to "pause internet" for another iOS device connected to my wifi, using the Network Map. Even though the "Pause internet" toggle is ON.
Jejskj
Jul 27, 2017Tutor
1.Model WNDR3400v2
2. Yes, installed app onto iPad, no luck
3. Yes, I uninstalled /reinstalled app, no luck
I also rebooted the router.
ljc2007
Jul 30, 2017Tutor
I am having the same issue. The app shows that the selected device is paused, but in reallity it is not.
I have also completed all the suggested tasks.
IPhone OS 10.3.3
Model # WNDR4500v2
firmware version V1.0.0.60
genie Version 3.1.28
- Steven_BelfastJul 31, 2017Apprentice
I assume the router is being used in router most and no ap mode ?
I have noticed that when i use the Orbi in AP mode pause stops working.
- ljc2007Jul 31, 2017Tutor
I'm not sure what app mode is.. I don't our internet provider connected the system up. I down loaded the netgear app for the parent controls.
- GHTAug 04, 2017AspirantSame problem here. Been going on for months. Used to work fine. Now, I can pause the internet on an iOS device connected to my router, then go into the statistics for that device and see the download/upload bandwidth unaffected.
Firmware V1.0.2.100
Genie version 3.1.28
