Mike9874
Apr 07, 2013Aspirant
Netgear Genie Questions
Ok guys, I have the desktop version of genie, using the R6300 router. Seems to work kinda ok, but the option on the network map for "Turn on access control" does nothing, just spins then dies. So w...
Gavin_Hossack
Apr 11, 2013Aspirant
Hey all,
I have a WNR2200 and this functions as well as can be expected, it's nothing special but it works.
I have the Genie app on my MacBook Pro and my iPad and would like to know how the remote login functionality works (which is apparently has) so that i can login into my network when i am not at home, which i needed to do last week when i had issues with my network (luckily i have a visitor network which was working well)
I would also like to know how to remove devices from my visitor network should i wish to, which i am informed is possible, but it doesn't explain to to do this in the manual.
Cheers all
Cheers all
