Asmith68
Jul 23, 2017Aspirant
Netgear genie R6400 port forwarding V1.0.1.24_1.0.18
I am trying to port forward for Xbox One. I have read the guide but things are not matching up. THe image shown in the guides does not match up with what I am seeing in my dashboard. The first imag...
TheEther
Jul 23, 2017Guru
The two images are functionally equivalent. The configuration in the 2nd image is set up for the most common use case, which is to forward external port X to internal port X. Just enter the port you want to forward in the field that says External Port Range. Then set Internal IP address to the device that you want to forward the port to.
