dvluft
Apr 01, 2015Novice
Netgear Genie reboots my PC
I installed Netgear Genie version 2.3.1.57 on my Windows 8.1 Pro computer so that I can setup parental controls. Since installing Netgear Genie, my computer reboots after it is idle for some period o...
dvluft
Apr 02, 2015Novice
microchip8 wrote: if i may ask, what leads you to conclusion that Genie is the actual cause for your reboot problem?
My computer was working fine for months. The reboot problem started after installing Netgear Genie, so I uninstalled it after a couple of days. My computer was working fine again, so I reinstalled Netgear Genie and the problem returned. No other software was installed during this period, so I concluded Netgear Genie is the cause.
