guatdad
Apr 02, 2017Tutor
Netgear Genie Remote access Registration failed
I bought a Netgear Nighthawk R7000 in April 2014 so support has ended. I have been trying to setup the Netgear Genie to allow remote access. Even though Netgear shows the router as registered under m...
DexterJB
Apr 07, 2017NETGEAR Moderator
You can check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/26109
There is an Unregister button available on the NETGEAR Genie as indicated on step 11.
Dexter
Community Team
guatdad
Apr 07, 2017Tutor
I do not have the Unregister button probably because the router does not recognized it is indeed registered even though it is.
- DexterJBApr 12, 2017NETGEAR Moderator
- Rizzol13May 16, 2017Aspirant
I'm also having this exact issue. What can I do to fix it?
- felix4tuneJun 28, 2017Aspirant
Hi, I too have the same issue. I had to reset to factory settings and now cannot register for remote management as the desktop app states that this product is already registered.
PLEASE HELP!!
