guatdad
Apr 02, 2017Tutor
Netgear Genie Remote access Registration failed
I bought a Netgear Nighthawk R7000 in April 2014 so support has ended. I have been trying to setup the Netgear Genie to allow remote access. Even though Netgear shows the router as registered under m...
guatdad
Apr 07, 2017Tutor
I do not have the Unregister button probably because the router does not recognized it is indeed registered even though it is.
DexterJB
Apr 12, 2017NETGEAR Moderator
- Rizzol13May 16, 2017Aspirant
I'm also having this exact issue. What can I do to fix it?
- DexterJBMay 16, 2017NETGEAR Moderator
Hi Rizzol13,
1. What is the model number and firmware version of your device?
2. Please provide more information regarding the issue, your setup, and steps taken.
Dexter
Community Team
- guatdadMay 17, 2017Tutor
Nighthawk R7000
v1.0.7.12_1.2.5
I have gone through the process of restoring to factory defaults. Before wiping, I downloaded the latest firmware. I wiped it and then loaded the newest firmware.
