guatdad
Apr 02, 2017Tutor
Netgear Genie Remote access Registration failed
I bought a Netgear Nighthawk R7000 in April 2014 so support has ended. I have been trying to setup the Netgear Genie to allow remote access. Even though Netgear shows the router as registered under m...
Rizzol13
May 17, 2017Aspirant
I have followed all the steps online and don't have an unregister button.
DexterJB
May 30, 2017NETGEAR Moderator
Hi Rizzol13,
1. Have you tried resetting the router?
2. Have you tried re-flashing the firmware then doing a factory reset?
Dexter
Community Team
- DexterJBJun 06, 2017NETGEAR Moderator
Hi Rizzol13,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- bripab007Jun 09, 2017Tutor
I just upgraded my R7000 from 1.0.7.x.x. firmware to the newest 1.0.8.34, and I'm unable to manage remotely via Netgear Genie app. Managing remotely via web URL still works fine.
Is this a FW bug? I don't see any register/unregister fields in my router. Do I need to turn off remote management and then back on to re-enable?
