guatdad
Apr 02, 2017Tutor
Netgear Genie Remote access Registration failed
I bought a Netgear Nighthawk R7000 in April 2014 so support has ended. I have been trying to setup the Netgear Genie to allow remote access. Even though Netgear shows the router as registered under m...
DexterJB
Jun 06, 2017NETGEAR Moderator
Hi Rizzol13,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
bripab007
Jun 09, 2017Tutor
I just upgraded my R7000 from 1.0.7.x.x. firmware to the newest 1.0.8.34, and I'm unable to manage remotely via Netgear Genie app. Managing remotely via web URL still works fine.
Is this a FW bug? I don't see any register/unregister fields in my router. Do I need to turn off remote management and then back on to re-enable?
- DexterJBJun 19, 2017NETGEAR Moderator
Hi bripab007,
Please make sure you do a factory reset after updating the router's firmware.
Dexter
Community Team
- DexterJBJun 23, 2017NETGEAR Moderator
Hi bripab007,
Dexter
Community Team- bripab007Jun 23, 2017Tutor
Hi, I actually just went through the password reset and got it working. I'm not sure why it didn't like that password because it was the same one I'd been using on other firmwares and I was still able to login to the netgear support site with that password...oh well, it's working now.
