guatdad
Apr 02, 2017Tutor
Netgear Genie Remote access Registration failed
I bought a Netgear Nighthawk R7000 in April 2014 so support has ended. I have been trying to setup the Netgear Genie to allow remote access. Even though Netgear shows the router as registered under m...
DexterJB
Jun 23, 2017NETGEAR Moderator
Hi bripab007,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
bripab007
Jun 23, 2017Tutor
Hi, I actually just went through the password reset and got it working. I'm not sure why it didn't like that password because it was the same one I'd been using on other firmwares and I was still able to login to the netgear support site with that password...oh well, it's working now.
- DexterJBJun 29, 2017NETGEAR Moderator
Hi Khobbs1,
It would be best if you will be on site with the device to perform troubleshooting. You can try resetting the router and go through the setup for remote login. The link below may help.
http://kb.netgear.com/app/answers/detail/a_id/26109
Dexter
Community Team
Hi felix4tune,
1. What id the model number and firmware version of the router?
2. Are you still able to login using the credentials that you have setup?
3. If yes, you should have the option to un-register the device.
Dexter
Community Team
- Khobbs1Jun 29, 2017Aspirant
Thanks for the response, here are the responses to your questions:
model is wnr2000v4, don't know firmware, as router is inaccessible
i am able to login to net gear genie app on multiple devices, none have router listed
physically b in gin front of router is NOT an option, it's more than 500 miles away.
accessibility did work on 3 different devices when tested on site. A Windows laptop, an iOS phone and tablet. Windows laptop is no longer available.
i am able to ping modem, but NOT router or a hard wired device attached to router or a wireless device connected to router. I have dns configured. I have tried using external ip as well as dns. I have modified port and login credentials on router.
i have an asus router configured for remote access as well and so far haven't had any issues.
thanks
- rajtechJun 30, 2017Aspirant
Model version: Netgear R7000
Firmware: V1.0.8.34_1.2.15
OS: Genie app on Mac and iOS
I used to be able to remote access earlier, but doesnt work after I had to reset the router when it froze. Through the genie app on Mac, when I try to login remotely, it gives the popup "The device is not registered. Do you want to register this router?" and then gives the error "The registration process failed, try again". Please advise how to unregister this device and re-register again. I cannot see the Unregister button as the login does not succeed. Thanks much.
- DexterJBJul 11, 2017NETGEAR Moderator
Hi Khobbs1,
The links below may help you out in setting up remote management for your device.
https://kb.netgear.com/976/Enabling-your-router-s-remote-management
https://kb.netgear.com/20600/Configuring-Remote-Management-on-a-NETGEAR-Router
Dexter
Community Team
- rajtechJul 11, 2017Aspirant
I had tried all this but to no avail. But when I tried it today, I could see remote access turned on in the Genie iOS app. Glad it works now. Much appreciated. Thanks Dexter
