jkk6861
Sep 06, 2016Aspirant
netgear genie remote log in
I just got my new nighthawk router and hooked it up yesterday. i also downloaded the genie app on my samsung s7. i am able to use the network map at the home setting but when i try to do remote setti...
DexterJB
Sep 19, 2016NETGEAR Moderator
Hi jkk6861,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
jkk6861
Sep 19, 2016Aspirant
yes i am. i am thinking about uninstalling the app and then starting over? also, i was kind of confused when i set it and the new router originally so who knows what i did!
