xxxxxxx
Oct 16, 2015Guide
Netgear Genie 'Router Login' problem
When I got my Netgear CG3000D cable gateway I changed Remote Management's 'Remote User Name' & 'Remote Password'. Then I discovered Netgear Genie. But now when I try to use Netgear Genie's 'Router Lo...
DexterJB
Oct 19, 2015NETGEAR Moderator
Hi xxxxxxx,
Have you tried resetting the device back to factory defaults?
Dexter
Community Team
Cruelman
Oct 19, 2015Aspirant
I have the exact same issue, but I use admin as user name, so fine by me. It has worked for some time now, but all of a sudden I can't login?! I tried changing the password but I says login failed please use correct password blah blah? Wth is that all about?? I run iOS 9, maybe that's the problem?? And don't ask me to reset to factory, why would I want or have to do that??
besides this kind of annoying issue, I freakin love my Nigthhawk, woof!! Glad I exchanged my Asus router for this :0)
regards
jesper
- xxxxxxxOct 20, 2015Guide
Hey Cruelman,
Try logging in as
Username: MSO
Password: changeme
I found that tip as I searched the Internet. Netgear doesn't have it in the documentation, but it worked for me. Then I changed the password. I recommend that if this works for you, you should change the password also. Otherwise, anyone who knows that remote login can zombiefy your modem.
