Tim_E
May 11, 2017Aspirant
Netgear Genie Software
I have a Smoothwall firewall set up as DHCP server in a rack with a fresh FreeNAS box. My network is primarily gigabit with Cat 5e and Cat 6 cabling. The leg with the WNR 2000 is connected to one e...
DexterJB
May 16, 2017NETGEAR Moderator
Hi Tim_E,
This is a very strange occurrence.
1. What version of the Genie do you have installed?
2. Does the issue persists on a machine where Genie has never been installed?
3. Does the issue persist on another machine (mobile devices included) where Genie is also installed?
Dexter
Community Team
sktn77a
May 17, 2017Virtuoso
Have you timed your transfers manually? I suspect the software is reporting the speeds incorrectly.
- Tim_EMay 17, 2017Aspirant
I transferred about 21 TB of data across the connection, the time difference was very noticible, as many of the transfers were done in 300gb to 1tb sections. I wasn't using synthetic benchmarks.
