Tim_E
May 11, 2017Aspirant
Netgear Genie Software
I have a Smoothwall firewall set up as DHCP server in a rack with a fresh FreeNAS box. My network is primarily gigabit with Cat 5e and Cat 6 cabling. The leg with the WNR 2000 is connected to one e...
DexterJB
May 16, 2017NETGEAR Moderator
Hi Tim_E,
This is a very strange occurrence.
1. What version of the Genie do you have installed?
2. Does the issue persists on a machine where Genie has never been installed?
3. Does the issue persist on another machine (mobile devices included) where Genie is also installed?
Dexter
Community Team
Tim_E
May 17, 2017Aspirant
My version is 2.4.38. Whenever it asks for an update, I let it update. I have a few gigabit machines on my network, but none have the storage to move that much data around on it for thorough testing. I understand why you would ask the second two questions, but I don't regularly move that much data around my network. I monitored the transfers closely, and the effect was 100% repeatable.
For my normal day-to-day conditions it should never be an issue. My only other bigger data machine had Genie installed on it as well, and it's not worth my time to flatten so I can test with a never-Genie'd system. I had Genie installed as a quick way to look at my connected devices without logging into my smoothwall to see them. It ended up on pretty much every laptop I own.
(FVX-538 v2, 2xWNDR 3700, 3xWNR 2000, 3xGS108, 3xGS605, 4xAV500)
