levince107
Oct 13, 2014Follower
Netgear genie support
Hi everybody I've just bought the netgear Nighthawk R7000 All works fine but when I click on parental control, I land on a web page where I have to dowload Netgear Genie. When I install netgear...
fax
Oct 26, 2014Aspirant
Otherwise you could also disable DHCP in belgacom BBOX3 and keep the default IPs range in NETGEAR (192.168.1.0/255.255....) but then if, for what ever reasons, you need to login again to your BBOX then you need to reset it.
I give as granted that WIFI in BBOX3 is OFF. When everything is setup correctly you will see three green lights in BBOX3. One is the power, one is related to DSL and the last linked to your R7000 attached to the BBOX. If you seem more than you are not in an ideal setup
Cheers,
Fax
Cheers,
Fax
