llalonde
Oct 31, 2015Initiate
Netgear Genie unusable on Mac
Hello Folks, Netgear genie is unstable on a Mac (El Capitan). I cannot quit the application once I've finished using it. I have to do a 'Force Quit' to kill the application. Anyone have...
skydevilace
Dec 09, 2015Aspirant
Having a problem with Netgear genie on iMAC using Yosemite. Need to log in multiple times. Also need to force quit after using. Have downloaded several times to no avail.
DexterJB
Dec 12, 2015NETGEAR Moderator
Hi skydevilace,
This issue is already being looked at and worked on by engineering. We do apologize for the inconvenience. Please do check for available updates for the app.
Dexter
Community Team
- DanzjenJul 13, 2016Initiate
I have the same problem, cant qoit the program on El Capitain
- Bharathy84Aug 20, 2016Aspirant
I also have the same problem... This issue is happening for a long time.. Netgear is not interested in fixing this... Pathetic !!!
- DexterJBAug 24, 2016NETGEAR Moderator
Hi Bharathy84,
Do you have to force quit the app as well in order for it to close? Are you experiencing other issues as well?
Dexter
Community Team
