llalonde
Oct 31, 2015Initiate
Netgear Genie unusable on Mac
Hello Folks, Netgear genie is unstable on a Mac (El Capitan). I cannot quit the application once I've finished using it. I have to do a 'Force Quit' to kill the application. Anyone have...
DexterJB
Nov 02, 2015NETGEAR Moderator
brie
Jan 23, 2016Tutor
why not post public solution? i had a similar problem too but just killed the app via terminal as any net.geek would do. bigger issue unable to find anywhere is how to UNINSTALL the (cr)app? i assume the installer is adding all sorts of daemon-ic detritus, so simply dragging to trash can't be enough. please help & add to genie FAQ or manual!
- fradanFeb 27, 2016Initiate
Same here (running latest version of Genie on Yosimite 10.10.5).
Have to force quit every time to get out of app and enter password multiple times.
How much longer before a fix?
Thanks
- DexterJBFeb 29, 2016NETGEAR Moderator
Hi @fradan,
No ETA on the next update yet.
Dexter
Community Team
- MFMiltichApr 09, 2016Aspirant
Same problem. Genie doesn't Quit - I have to use Force Quit to stop the Beach Ball of Death. I'm using MacBook Pro Retina (mid '12) and OSX 10.11.13. This has happened ever since I've tried using Genie and just downloaded the latest version, and it still is happening. Not nice!
