llalonde
Oct 31, 2015Initiate
Netgear Genie unusable on Mac
Hello Folks, Netgear genie is unstable on a Mac (El Capitan). I cannot quit the application once I've finished using it. I have to do a 'Force Quit' to kill the application. Anyone have...
DexterJB
Dec 12, 2015NETGEAR Moderator
Hi skydevilace,
This issue is already being looked at and worked on by engineering. We do apologize for the inconvenience. Please do check for available updates for the app.
Dexter
Community Team
Danzjen
Jul 13, 2016Initiate
I have the same problem, cant qoit the program on El Capitain
- Bharathy84Aug 20, 2016Aspirant
I also have the same problem... This issue is happening for a long time.. Netgear is not interested in fixing this... Pathetic !!!
- DexterJBAug 24, 2016NETGEAR Moderator
Hi Bharathy84,
Do you have to force quit the app as well in order for it to close? Are you experiencing other issues as well?
Dexter
Community Team
- Bharathy84Aug 25, 2016Aspirant
Yes. I have to Force Quit the application everytime because I get beach ball when I do (Command + Q).
When I tried to execute (Command + Q) immediately after opening the app then the app quits !!!
Also the CPU usage of the app become very high after sometime... That's when I think quit does not work.
Bharathy
