Richard_Kimber
Aug 27, 2017Aspirant
Netgear Genie V1.1.0.42_1.0.1 gives wrong information
I have just bought an R6800-100UKS which works well with BT infinity 3, except that the NETGEAR genie Basic Home page says that I am not connected ! The Advanced Connection Status says that I am ...
Richard_Kimber
Aug 29, 2017Aspirant
Thanks, but I don't use any anti-virus program. Are you saying that it could be a browser issue?
William10a
Aug 29, 2017Master
Genie has issue some times just because of any possible problem it sees but is not a problem like you said it is a max of good and bad and yours is the must common posting with ready share a close follower in the postings even Windows can make the two actup if Microsoft changes some of its coding. So like you said it is buggy from time to time until they find what is causing it.
