Loganrun
Sep 13, 2018Tutor
Netgear Genie Version 2.4.38 Troubleshooting
Recently updated Genie desktop software (ver 2.4.38) on Mac (ver 10.13.6). Software will now show Network Map in continual scanning and not update devices. I have uninstalled and reinstalled and st...
Macropod71
Sep 17, 2018Initiate
Same here since download of 2.4.38 on OSX yesterday. Also get same result on work network.
- schumakuSep 17, 2018Guru - Experienced User
Same problem reported in the more appropriate Genie App subforum section
Netgear Genie - Network Map fails
Devices disappeared from network map
FWIWSame problem here on my MacOS systems, Genie (MacOS) 2.4.38 on both Yosemite and High Sierra. Regardless if connected to a network with a Netgear router (R9000 1.0.4.12) or a different network - where the Windows version does work like a charm.
Unlikely router firmware specific - as both the MacOS and the Windows Genie scan and discover the Network Map independent of a router!
@ChristineT again a longer standing issue, spreading all over the community.
- Kendal857Sep 29, 2018Aspirant
Same issue running OS X 10.12.6 Sierra. No problem until downloading the latest version. No issue when monitoring my network from the Nighthawk iOS app version 2.2.6.16.
- DexterJBJan 07, 2019NETGEAR Moderator
Hi all,
Update: Engineering is currently completing the build for the fix and may be included in the next release.
Dexter
Community Team
