Loganrun
Sep 13, 2018Tutor
Netgear Genie Version 2.4.38 Troubleshooting
Recently updated Genie desktop software (ver 2.4.38) on Mac (ver 10.13.6). Software will now show Network Map in continual scanning and not update devices. I have uninstalled and reinstalled and st...
schumaku
Sep 30, 2018Guru - Experienced User
Typo fixed above.
LALB wrote:
Is Netgear working on a solve for this issue?
Most active community people are not working on behalf of Netgear - go figure...
Loganrun
Sep 30, 2018Tutor
I am original poster and I have been working with Netgear support but as of today there has been no solution to the device map problem. They see no problem using a R7000 router in their lab and they sent me a new replacement but that still did not fix the problem in my situation. The case number is still open for now. Hopefully more trouble shooting this week.
- schumakuSep 30, 2018Guru - Experienced User
It's not a specific router model or router firmware problem - both the macOS Genie as well as the Windows Genie are building the Attached Device map partially independent of the existence of any Netgear router - complete odd design. Same issue with an R9000 (1.0.4.12) serving the Internet connection for example, and many more combinations.
- LALBSep 30, 2018Tutor
Thank you for the info. The issue is obviously global since many of us had a similar issue that occurred oly after this latest version update. Please post something here once they say they're putting out a correction.
I will also add, since it seemingly hasn't been made clear, that this is wreaking havoc with the connectivity of all of the devices on my network. Its not just that the mapping feature isn't showing up.
Unrelated to the Netgear Genie App resp, the Nighthawk App.
Dozens of other threads with virtually hunderds of posts discussing and complaining on the R7000 V1.0.9.34 issues. It does not help to mix up things here.
