Walley
Nov 14, 2014Follower
NETGEAR Genie *Virus*
I just upgraded the Netgear Genie through its user interface after installation was completed Symantec popped up with a virus. :eek: Filename: NETGEARGenie.exe Risk: Suspicious.Cloud.5 Action: ...
randallhill
Nov 14, 2014Aspirant
Same with me NetgearGenie v2.3.1.46...NIS 2014 blocked the update install exe file as "suspicious cloud.5. I disabled anti-virus auto-protect was able to install the update, but when I run NG, NIS gives me a "threats detected" message, also NG doesn't run correctly, can't log into router R6300v2 or access ReadyShare USB drive. Guess I'll uninstall the update and reinstall the previous version.
