L-Rod
Oct 10, 2022Aspirant
Netgear Genie vs Nighthawk app
I previously owned a Nighthawk R8500 that was managed by the Netgear Genie. The R8500 died (I suspect the cat laying on it had something to do with that). Just purchased a Nighthawk RAX43, downloaded...
Oct 11, 2022Guru - Experienced User
They're available if you do a network scan? You can see something still broadcasting that ssid?
Got a screen snip?
L-Rod
Oct 11, 2022Aspirant
Guru, yes, they're visible in network scans, screenshot attached. The SSIDs with "Private" in the name are the old ones created with Netgear Genie.
