utschy
Nov 15, 2015Initiate
Netgear Genie will not work on my new Windows 10 machine. Closes immedieately
Hi, Just got a new HP Spectre 360. It installs and just as it is opening, a dialog box "Netgear Genie has stopped working. Aproblems caused the program to stop working correctly. I uninstalled the ...
utschy
PS,
I just downloaded the program today from the netgear website that was listed as the "solution" to the problem. This must be the latest version of this program.
DexterJB
Nov 16, 2015NETGEAR Moderator
Hi utschy,
We apologize for the inconvenience that this has caused you. Rest assured, we are working on a fix. Just to make sure, you may use the download link below for the previous version (2.4.12) of the NETGEAR Genie program.
http://files.netgear-support.com/go/?a=d&i=cEJUI5BJSJ
Dexter
Community Team
- truthreignsDec 30, 2015Aspirant
There is a blank page at this link
- DexterJBDec 30, 2015NETGEAR Moderator
Hi truthreigns,
Please try using another browser or computer. If that does not work, you can use the alternative download link below.
http://files.netgear-support.com/go/?a=d&i=BhR0tfRuDa
Dexter
Community Team
- glennb12345Mar 27, 2016Aspirant
I'm having the same issue. I installed the latest Genie update and now it will not work. I tried uninstalling and reinstalling it from your website, but still not working.
Surface Pro 3
Windows 10
Norton Security
Netgear R7000 router
- DexterJBMar 27, 2016NETGEAR Moderator
Hi @glennb12345,
You may follow the steps below as a temporary work around.
1. Install the latest version of NETGEAR Genie. You may use the download link below.
http://netgear.com/home/discover/apps/genie.aspx
2. Once you have successfully installed the program, navigate to C:\Program Files (x86)\NETGEAR Genie\bin
3. Delete the drivers folder.
4. Download the drivers for the previous version of NETGEAR Genie using the download link below.
https://drive.google.com/file/d/0Bz-pjmQaYmk6Z0xTX3d3SVFLZ0k/view?usp=sharing
5. Unzip the file to your preferred location (Desktop would be easy to locate). It will contain the drivers folder.
6. Copy the drivers folder that you have just unzipped and navigate back to C:\Program Files (x86)\NETGEAR Genie\bin
7. Paste the drivers folder.
8. Relaunch the NETGEAR Genie programRegards,
Dexter
Community Team
- gcrowellApr 11, 2016Initiate
Finally, This worked!
Dexter
Community Team
