utschy
Nov 15, 2015Initiate
Netgear Genie will not work on my new Windows 10 machine. Closes immedieately
Hi, Just got a new HP Spectre 360. It installs and just as it is opening, a dialog box "Netgear Genie has stopped working. Aproblems caused the program to stop working correctly. I uninstalled the ...
utschy
PS,
I just downloaded the program today from the netgear website that was listed as the "solution" to the problem. This must be the latest version of this program.
owl1000
Nov 24, 2015Aspirant
I have a similar issue not update provided for windows 10 a pathetic response. There should have been an immediate update provided for a major product release like Windows. Next time I will be more careful to buy a product with decent support
- DexterJBNov 24, 2015NETGEAR Moderator
Hi owl1000,
We are looking into this situation since not all Windows 10 devices are affected. Considering that Windows 10 is a fairly new release, there are plenty of under the hood updates that are continuously being pushed out that may not play well with some programs. Installing the previous of NETGEAR Genie is a temporary work around for now. If you have not installed it yet, you can use the download link below.
http://files.netgear-support.com/go/?a=d&i=i82p82s4Oy
Dexter
Community Team
- BillB1234Dec 07, 2015Guide
Thank you for this workaround.
Genie version 2.4.16 does not work on my Lenovo IdeaCentre 300S-08IHH running Windows 10-64 Home. The older Genie version 2.4.12 does work.
- Ole_RollDec 12, 2015Initiate
Neither of the links you posted work. The files do not exist. Is there an update?
- DexterJBDec 13, 2015NETGEAR Moderator
Hi Ole_Roll,
Please try downloading the latest version (2.4.20) from the website and see if it works. You may use the link below.
http://netgear.com/home/discover/apps/genie.aspx
Dexter
Community Team
