utschy
Nov 15, 2015Initiate
Netgear Genie will not work on my new Windows 10 machine. Closes immedieately
Hi, Just got a new HP Spectre 360. It installs and just as it is opening, a dialog box "Netgear Genie has stopped working. Aproblems caused the program to stop working correctly. I uninstalled the ...
Ole_Roll
Dec 12, 2015Initiate
Neither of the links you posted work. The files do not exist. Is there an update?
DexterJB
Dec 13, 2015NETGEAR Moderator
Hi Ole_Roll,
Please try downloading the latest version (2.4.20) from the website and see if it works. You may use the link below.
http://netgear.com/home/discover/apps/genie.aspx
Dexter
Community Team
- BillB1234Dec 13, 2015Guide
Dexter - I'm sorry but "see if it works" isn't an answer.
Before I try 2.4.20, I would like to know if those that had trouble with 2.4.16 on Windows 10 can get 2.4.20 to work. Otherwise, I'll stick with 2.4.12 until this is a confirmed fixed. It took me a long time to remove all vestiages of 2.4.16 after uninstalling in order to install 2.4.12. I'd like to know for sure that 2.4.20 is a fix.
Also, that link is version 2.4.18.
- petey5927Dec 14, 2015Initiate
Hi Dexter,
I am having the same poblem and the new version of the genie that you provided the link too still is not working with Windows 10. The program stops working as soonas it is opened. Also, the previous links provided are not working. The file requested is not found. Is there another workaround for this issue?
Peter
- DexterJBDec 15, 2015NETGEAR Moderator
Hi BillB1234,
We sincerely apologize for this inconvenience. I recommend sticking with the version 2.4.12 for now until I am able to confirm if the changes will fix the issue. We are currently investigating the root cause of this. May I also know if your Windows device was upgraded from 8.1 to 10?
Dexter
Community Team
Hi petey5927,
We are in the process of investigating the cause of the issue. May I know if you have updated the Windows device from 8.1 to 10?
You may use the download link below for the previous version.
http://files.netgear-support.com/go/?a=d&i=X7dehTxygH
Dexter
Community Team
- hphvDec 28, 2015Aspirant
same here 2.4.20 also crashes in win 10 1511
- Angelo1112Feb 02, 2016Aspirant
The link provided plus what is offered as the latest version of Genie is not to 2.4.20, but to 2.4.18. Is there really a version 2.4.20?
- GSSFeb 02, 2016Aspirant
Genie 2.4.16 and 2.4.20 do not work with w10! Only 2.4.12 works with w10
- BillB1234Feb 02, 2016Guide
Genie 2.4.16 will work with Windows 10 if you follow the previously posted steps to copy the 2.14.12 drivers over to 2.4.16.
I don't know what's new in 2.4.16 from 2.1.12. It may not be worth the effort unless there's something you need in 2.4.16. I copied them over to help test this workaround.
