utschy
Nov 15, 2015Initiate
Netgear Genie will not work on my new Windows 10 machine. Closes immedieately
Hi, Just got a new HP Spectre 360. It installs and just as it is opening, a dialog box "Netgear Genie has stopped working. Aproblems caused the program to stop working correctly. I uninstalled the ...
DexterJB
Dec 15, 2015NETGEAR Moderator
Hi petey5927,
We are in the process of investigating the cause of the issue. May I know if you have updated the Windows device from 8.1 to 10?
You may use the download link below for the previous version.
http://files.netgear-support.com/go/?a=d&i=X7dehTxygH
Dexter
Community Team
Johnwolfe13
Dec 17, 2015Aspirant
I agree with the other two posters: as a new pre-installed Windows 10 user version...12 works good. Thank you Dexter!
- Dan12Dec 24, 2015Aspirant
Had the same problem, latest verision of Netgear Genie wouldn't work on my new Lenovo destop with Windows 10 installed, uninstalled the new version and installed ver. 2.4.12 and the older version works for me too.
Thanks for the information!
